Mk4 rear Light?
Kev10001
Mk4 rear Light?
Post by Kev10001 »
Guys is it possible on a 2014 to brighten the lower light bar with Vag can pro , like you can do on the earlier caddys when fitting mk4 rear lights with vcds ? Cheers
STP
Re: Mk4 rear Light?
Post by STP »
Haven't tried it but have considered it on my 2015 with standard lights. There's a percentage setting which should be available via Obdeleven or VCP or VCDS and although I have all three, I've not tried yet. They are a bit dull and dreary aren't they.
Let's compare notes on here. Going to try Obdeleven first as I always have that with me. Next I was going to use VCP and VagHelper anyway to disable the led drl warnings for side lights so I will try that soon ( it takes up more time than I have at the moment to lug the laptop out and sit in the van fiddling with the coding options but am on holiday for a week on March so should find time then) but will report back on tail light brightness changes if they are possible.
