I've had my van liveried now, and solid rear window guards fitted. I'm going to remove the rear wiper, however I wanted to have a "belt & braces" approach and whip out the fuses for the rear wiper and washer pump.
However, neither the van nor the handbook give any indication of which fuse is in which location ... anyone on here know, or got a link to the information? For reference, it's a 1.6 TDi 100hp.
Fuse Numbers - 2012 Caddy
- NornIron
Ich habe kein Geld!
- marain
- minibikepro31
Re: Fuse Numbers - 2012 Caddy
i may be wrong but the washer motor pumps forward to the windscreen and backwards for the rear windows. so if you pull the fuse you will have no washers at all.
You can turn off the rear via vcds or just put a bolt in the pipe and put a zip tie around it.
IN THE BOOST!
- NornIron
"You are not authorised to read this forum."marain wrote:Tty this
viewtopic.php?f=6&t=5402
I gotta admit... this really p****s me off on this forum, as whenever a newbie tries to search for basic questions, access is denied
I must post a couple of hundred random messages just to get access
Ich habe kein Geld!
You've obviously not read ALL the topics that are available to you or you would have seen the appropriate one to ask for extended access.
If you like, I'll refund your subscription and you can clear off?
- NornIron
Mmmm... with an admin response like that, do I want to be part of the communityDoc wrote:You've obviously not read ALL the topics that are available to you or you would have seen the appropriate one to ask for extended access.
Ich habe kein Geld!
In fairness, saying you are going to
On a forum I've put over 4 years hard work and my own money into isn't going to help. If you know the rules, why not just ask for permission like everybody else??NornIron wrote: post a couple of hundred random messages just to get access
- NornIron
With a "laughing" smiley? I assumed people understood jokes, as a number of other members recommended this forum to me, because it was "useful, informative and good banter".Doc wrote:In fairness, saying you are going to On a forum I've put over 4 years hard work and my own money into isn't going to help.
Not for me...
Ich habe kein Geld!
