Bought another one
Swapped the mk3 rear clusters for tinted mk4's
- Bjd198
Love this mod, this is top of my list to do. Are you getting any bulb errors? And where were your lights from?
Today I put in a pd130 looks bit lower on the right not sure if that’s normal or if I’ve used a wrong mount
@Bjd198. Lights were from Travelin lite but I know vanstyle also do them amongst others. Yes there is a bulb error caused by the non-connected reverse lamp on the drivers side. I will get this coded out. You could fit a resistor but not my chosen solution.
Ceramic coated the new alloys ready for fitting
I finally washed it
Ummm... No exactly sure how it's happened but that's another but I need off the touran before it goes for scrap.
Sent from my POCOPHONE F1 using Tapatalk
Finally got round to removing the scuttle panel in the engine bay and cleaning out the forest which was developing there between that and the back of he dash. Even managed to locate the drain holes which are now free of debris.
Replaced the third row rear life seat I had for some Touran seats..
just the last bit of rear floor to finish.
Got my rcd330 with android auto in seems a bit laggy in the 10 minutes I've used it but very happy with the features, hopefully it doesnt stay laggy and is more of a just booted up for the first time in ages sort of thing
More to follow
More to follow
Replaced middle air vents from dashboard
I changed over the knackered side door lower roller and the rear N/S check strap.
Both an absolute piece of cake....which was nice
Fitted new rear bumper . Bit of a pain getting the old rusty screws off of the crash bar but with the help of a friend and some brute force we got it . Not sitting quite right at the corners think it needs a different bracket but it’s on for now and looking much better than the battered old one it replaced
