Toffee delights
Lister79
Toffee delights
Post by Lister79 »
Cheers mate. Wheels are just like bikes and everything else Pete, N+1 it the perfect quantity. But I’ve currently got 4 sets, which is 3 sets more than I need according to the wife.
I haven’t had any real reliability issues with them considering the conditions they are exposed to, and the ease of charging them is great.
Billy.2kcaddy
Re: Toffee delights
Post by Billy.2kcaddy »
Wheels look unreal.
I was under the impression that Mercedes wheels didn't fit because the lug holes were smaller?
Sent from my SM-S908B using Tapatalk
Reason: Quote of previous post removed
Re: Toffee delights
Yes, you’re right. I have too many examples of quite a few things. Gets expensive sometimes!
Good to hear you’ve not had too many issues mate, least you can do the work yourself
Lister79
Re: Toffee delights
Post by Lister79 »
Thanks Billy.2kcaddy
No the merc wheel bolts are M14 the same as VW, at least they are on these ones.
Billy.2kcaddy
Re: Toffee delights
No worries, I'll be looking at merc wheels in the future then aha.
Lister79
Re: Toffee delights
Post by Lister79 »
Rubbish weather at the minute so not ideal for working on the van, but today is a good day as the van is back at 100%.
Got the drivers side strut removed a couple of days ago, and checked for leaks. It turned out that an O-ring in the top sandwich plate was causing the main leak (in addition to the lower sandwich plate), so replaced that (thanks to Plush for getting one to me within 24hrs).
Had to drill out a number of screws that were seized/rounded off, so replaced them all. Also fit a new genuine strut top mount and all the removed fixings whilst it was in bits.
Blowing bubbles
All fixed
In work
Weylin_mordigan
Re: Toffee delights
Post by Weylin_mordigan »
This van is absolutely insane. Between yours and others I've mentally spend A LOT and I don't even have a van yet!! 🤣🤣🤣
Nath&Alex
Re: Toffee delights
Post by Nath&Alex »
Saw you’d got an issue on Instagram, but glad you’ve got it sorted 👍🏻 Sounds like brilliant service from Plush Automotive 😎
Reason: Quote removed
2012 Caddy 1.6 TDI Match, Darkside lowering kit with Bilstein coilovers, Lapiz blue Brembo 4pot front calipers & S3 rear calipers and Black 19“ Rotiform DTM wheels
Instagram @Nathadametzgibson
Build thread >>>here<<<
Projectil_CZ
Re: Toffee delights
Post by Projectil_CZ »
Is difficult change dashboard? Your Caddy is my dream
The_White_Van_Man
Re: Toffee delights
Post by The_White_Van_Man »
I follow you on Instagram, the Merc wheels are by far my favourite. You've done a cracking job on the van, it's definitely an inspiration to many.
Lister79
Re: Toffee delights
Post by Lister79 »
Thanks for the comments all.
The dashboard swap is a relatively easy job to do, as long as you have all the correct pieces required.
Lister79
Toffee delights
Post by Lister79 »
Another day, another air leak! This time it was the passenger side front leader hose bulkhead. I suspect the hose insert damaged the o-ring when removing it recently to replace the hose and elbow, and then the recent cold weather finished the job.
I don’t think it’s too bad, having just shy of 3 years of year round daily use and it’s only required 2 check valves, 1 strut rebuild and a couple of fittings. Saying that, hopefully there won’t be any more leaks for a while. Image
ToiletTFSI
Re: Toffee delights
Post by ToiletTFSI »
nice repair on the strut, not tempted to do the other front?
Lister79
Re: Toffee delights
Post by Lister79 »
Yeah I will be mate, I’ve got all the bits sat ready. I’m just waiting for some free time and the weather to improve/align, as it’s not great working outside at the minute.
Loz2286
Re: Toffee delights
Post by Loz2286 »
Lush looking van. Great build thread.
