The NEW retrofit thread
- Gresley
Re: The NEW retrofit thread
I think im going to get a set!
- maxx007at
Me too! They look nice.Gresley wrote:I think im going to get a set!
Tiguan 5N2 (2.0 TSI (CCZD) 4Motion, REMAP 158 KW/211PS)
Ex Caddy 2k (e.o.2004) (1.9 TDI(BJB), REMAP 103KW/145PS) Ravenna Blue
stan-the-man
bt79
Finally got my rear light installed.
- dan@biali
I've been looking at the mirrors for a member on here and thought I'd post up some part numbers. Not 100% sure at the moment as to exact fitment as etka is only listing basic info. Think these are for the Life so the smaller versions. Definitely listed as the RHD parts. There are also a load of different aerial combinations which I'm not going to list!
Satin black frame (main mirror housing):
2K6 857 407/408 9B9 left/right £60 listed as 'adjustable from outside'
2K6 857 407/408 A 9B9 left/right £112 electrically adjusted, seperately heated
2K6 857 407 D/408 F 9B9 left/right £118 electrically adjusted, heated, foldable
Underlay:
2K5 857 543/544 A left/right £5 (its possible this is identical to the older Caddy part)
Bezel satin black:
2k5 858 553/554 9B9 left/right £14
Mirror glass:
2k6 857 521 left £40
2K6 857 521 A left heated £54
2K6 857 522 right wide angle £47
2K6 857 522 A right wide angle heated £62
Mirror cap:
2K5 857 527/528 9B9 left/right satin black £11
2K5 857 527/528 B GRU left/right primed £31
Underlay:
Bezel satin black:
Mirror glass:
Mirror cap:
dabi
Anyone have a link to the rear tail lamp upgrade DIY? Thanks in advance
- maxx007at
Here you go:dabi wrote:Anyone have a link to the rear tail lamp upgrade DIY? Thanks in advance
http://www.caddy2k.com/forum/viewtopic.php?t=23904
Read through it all I'd suggest.
If you have questions, we are here to help
WelshCaddy
I see this question asked a lot, but no replies...
Has anyone fitted these rear lights to the models before 2011?
Also the new mirrors, are they a direct replacement?
Thank You
Thank You
- maxx007at
Yes I have, mine is from 2004-10WelshCaddy wrote:I see this question asked a lot, but no replies...
Thank You
Same pin swap needs to be done though
WelshCaddy
the long one
dan@biali wrote:I've been looking at the mirrors for a member on here and thought I'd post up some part numbers. Not 100% sure at the moment as to exact fitment as etka is only listing basic info. Think these are for the Life so the smaller versions. Definitely listed as the RHD parts. There are also a load of different aerial combinations which I'm not going to list!
Underlay:
Bezel satin black:
Mirror glass:
Mirror cap:
Just did this with the help from Stan the man
No need to buy the underlay and bezels as they come with the mirror
Had to repin door modules and looms but did change to a later version
- maxx007at
And did you go for the electric foldable ones?
Verzonden vanaf zo'n fruitig dingetje.
the long one
Yes I did fit the folding mirrors at long last I now have two mirrors the same size . I had to change the pin layout on the door module (now gen 3), door card loom (2010 on) and new mirrors (new caddy 4 small) . For some reason the mirrors worked backwards so that could have been down to module orgin (no idea off what)
timdigings
Hi, new to all this, sorry if this is in the wrong place.
I'm after some advise about door wiring.
I'm wanting to fit heated mirror glass to my manual caddy mirrors. I see I can buy the switch easy enough and the heated replacement mirror glass should fit. I reckon I can get wires through the mirror hinges to power them but not sure what to do with respect to wiring looms.
Does anyone know if the wiring harness which links the door to the rest of the car is different for manual and electric mirror versions? i.e. are there just bits missing in the door? There is a black control box behind the door card, I'm kinda hoping I can get a bit of loom that plugs into this?
Any advise would be greatly appreciated
Thanks, Tim
Thanks, Tim
the long one
dan@biali wrote:Rear bumper is:
2K5 807 417 GRU primed and is about £260.00
There are also textured plastic ones but still expensive at £235.00 and then there are also versions for vehicles with park assist system.
Looking at the drawings, the rear crash bar and the guide profile the bumper sits in look slightly different. It may not be the plug and play people want!
Old bumper:
New bumper:
Dan
Do you have any part numbers for these bits for a maxi ?
