Stop start function disabling
Caddy bridge
Post by Caddy bridge »
Is it possible to disable the stop start function ? I know there is a button to turn it off in the cab for a short while.
Torpa
Re: Stop start function disabling
Post by Torpa »
You can disable it with vcds but you will get a error message in the mfds.
I found a electronic device on ebay to connect to the stop start button that makes the button remember the last setting.
So if you have disabled stop start on button when you have parked the car, the next time you start no need to disable stop start again.
https://rover.ebay.com/rover/0/0/0?mpre ... 2352078637
From Sweden
Caddy bridge
So it can’t be turned off without bringing up a fault on the display?
Torpa
Post by Torpa »
No not what i could find, first i tried with vcds but only got the error messsage then i checked some Vag forums and i found that it was possible to disable it on some older Vag models.
But not im my case a 2013 Touran.
Google it and you will find alot about start stop.
From Sweden
Sportvan
Post by Sportvan »
On the rear terminal of the battery on my van (2017 Highline 150 DSG) there is a plug with two wires facing towards the front of the van, I unplugged that and it disabled the stop start.
Caddy bridge
And it’s not caused any issues?
mark1a
Post by mark1a »
Sportvan wrote: Sat Apr 21, 2018 8:17 pm On the rear terminal of the battery on my van (2017 Highline 150 DSG) there is a plug with two wires facing towards the front of the van, I unplugged that and it disabled the stop start.
Is that not the feed from the IBS, that enables other functions such as alternator charging on braking etc? What else is affected if the ECU is not monitoring flow in & out of the battery?
Sportvan
Post by Sportvan »
Didn’t seem to have any effect, van is running as normal. A lot of these systems have to meet so many parameters to operate I doubt they kicked in that much.
LeeH
Post by LeeH »
Why do you want to disable it out of interest?
2011 2.0 GT Bluemotion Tech DSG in Candy White
2012 1.6 Highline Bluemotion Tech Caddy in Indium Grey
Caddy bridge
It’s the only function I’m not keen on .
Sportvan
Post by Sportvan »
Stop start, it’s a pain in the arse with DSG and dangerous. The van has shut the engine off as you come up to roundabouts without it coming to a stop and if it’s clear and you want to go you have to wait for the sodding thing to start again. If I knew a way of disabling it permanently with VCDS I would.
I'm fairly sure it's not supposed to turn the engine off when you are still moving, I'd get that checked out by VW.
I've driven a few DSGs with start stop and never had a problem. I do tend to relax my pressure on the brake pedal once I'm at a complete stop, this might prevent the engine stopping as it'll be expecting the pedal to come up fully and set off.
stan-the-man
Post by stan-the-man »
Happened to me few times as well. Engine switched off while car was still rolling coming to a stop. Defo annoying. Trying to get the pcb board sorted so it will disable it hopefully. I didn’t try to mess with any coding to try
LeeH
Post by LeeH »
I don’t seem to have any issues at all with DSG to be honest in my wife’s Scirocco.
dan@biali
Post by dan@biali »
Whilst looking for something else I found this
http://www.canm8.com/special-vehicle-so ... d-off.html
Box that turns off start stop each time the ignition is switched on but it says you can also reinstate it once the engine is running.
It can be bought from a distributer here for £80 http://www.ncs-systems.com/canm8-ed-off.html
