Alloys for 2011 Maxi
- XTX
I have just got a 2011 Caddy Maxi (ex-BG), that has steel wheels fitted, which are battered.
I traded in my 2006 Skoda Octavia Estate but I still have the original alloys for it, which I would like to use on the Caddy if I can.
The label in the Caddy drivers side doorway says 6J x 16 (I don't have a user manual for the van) and the Skoda Alloys are 6.5J x 16 PCD 5 x 112.
Do any of you know if these will fit?
2011 ex-BG Caddy Maxi
liamcaddy61
Re: Alloys for 2011 Maxi
Should fit the 5x112 is the bolt pattern and the 6j is the width of alloy, think you can go up to 8/8.5j without the sliding door catching
- XTX
Brilliant thanks!liamcaddy61 wrote: ↑Sat Sep 28, 2019 7:34 pm Should fit the 5x112 is the bolt pattern and the 6j is the width of alloy, think you can go up to 8/8.5j without the sliding door catching
- Skully
What is the offset of the Skoda alloys?
There should be specs cast into the rear of one of the spokes that reads "ET**"
The ** denotes the offset and that is more important than the width of the alloy.
1996 Mk3 VR6
2017 Caddy Maxi 2.0 TDI
2013 RSV4 track bike
2021 Aprilia RS 660 road bike
liamcaddy61
my bad I dont have massive knowledge of alloys
- XTX
I am not sure, I will see if I can find it in the morning.
The spec sheet for the Skoda says ET50 and the alloys were genuine Skoda Octavia alloys, so I assume they would have been to spec.
- Tattoocaddy
Morning mate the et would need to be between et47 to et54 to be sure I'm running Audi A-line 19inch alloys on my maxi hope this helps
Sent from my LYA-L29 using Tapatalk
3_50
There's quite a good wheel and tire calculator here, and there's quite a lot of room in the caddy arches for bigger wheels, as others have said.
- XTX
Thanks guys, very helpful
I need to get my Skoda alloys refurbished now, some of them are not holding air because the paint is flaking in places.
A good rule of thumb with offset (the ET figure) is to stay with in +/- 5 of the original value. If I remember rightly, the standard 15” steels are ET47, so as low as 42 or as high as 52.
- Boonalon
I have A set of Octavia RS alloys they are 7Jx18’s with a ET of 51, no issue at all
They look well smart boonaloon
Dantee46
When changing to alloys are you using standard wheel bolts?
STP
Ideally get proper alloy wheel bolts, the part of the bolt under the head which contacts the wheel is a different shape from the steel wheel bolts. Those are domed and the alloy ones aren't from memory. Could bind up or not seat properly.
Roan’s Caddy
Those alloys look insane.
