Giddy
Post by Giddy »
It might be that one of the barn door catch/latch things need adjusting a tiny bit.
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
broadmoor
Post by broadmoor »
Giddy wrote: Sat Nov 23, 2019 7:01 pm It might be that one of the barn door catch/latch things need adjusting a tiny bit.
I’ve removed them for now.....will try again tmrw
PDC
Post by PDC »
Nothing too exciting, just fitted mud flaps & sticker today......
Josh764
Post by Josh764 »
@broadmoor your van looks awesome
PDC
Post by PDC »
Broadmoor, looking at your Caddy I think that I need to drop my rear end one more notch.....
broadmoor
Post by broadmoor »
I run the standard VW hangers, didn’t like the look of the multi position ones that came in the kit, sits just right at the rear for me
PDC
Post by PDC »
I never thought that the original hangers might offer the correct ride height that I like. I will offer the original hangers up to the multi point hangers and see if they do as you say. Cheers.
@ broadmoor, I know it sounds obvious but have you checked your side jack? I have to tighten mine quite often, it rattles like a swine when loose
Seanick
Post by Seanick »
Carpets and LEDs today ImageImage#vanlife Image
Josh764
Post by Josh764 »
@Seanick that looks super good carpet is next on my list of things to do.
Colour coded rear badge, installed dummy alarm led after rear window got smashed last week Image
broadmoor
Post by broadmoor »
the swan fiend wrote: Sun Nov 24, 2019 3:40 pm @ broadmoor, I know it sounds obvious but have you checked your side jack? I have to tighten mine quite often, it rattles like a swine when loose Image
I did matey , I’ve not had a chance to drive the van today since removing the door stays, pretty sure it was related to these
Hope you find the cause mate. Rattles are very annoying! Can’t understand anyone who says “just turn the radio up”
gary willis
Post by gary willis »
1st mod done Audi q5 s lines but anyone tell me what plugs are for what and is it possible to connect heated seats without wiring into the heater control
Baz78
Post by Baz78 »
Fitted new head unit and DAB aerial today as the original one was awful, no reception at all, can finally drive without losing signal :D
