Ryzar1
Posts: 639 Joined: Fri Aug 16, 2019 12:22 am
Post
by Ryzar1 » Sun Jan 19, 2020 2:46 am
No more dumbo ears
Vwjack88
Posts: 237 Joined: Sun Oct 07, 2018 1:08 am
Post
by Vwjack88 » Sun Jan 19, 2020 11:43 am
Mod number 2 for the van, engine cover
Posts: 5163 Joined: Sat Feb 18, 2017 10:52 pm
Post
by the swan fiend » Sun Jan 19, 2020 11:45 am
@James Tyrrell. Hi mate, welcome to the forum. You can upload photos straight from the off. I use the Tapatalk app and upload them through that.
Cultus
Posts: 110 Joined: Fri Mar 22, 2019 8:50 am
Post
by Cultus » Sun Jan 19, 2020 11:58 am
Rear cab lights kept coming on when the door sensor was triggering on and off as I was driving, eventually found the culprit.
It was a worn sensor latch, just filled with a little jb weld putty and it's working as it should now !
Sent from my ONEPLUS A6013 using Tapatalk
Fonzi
Posts: 56 Joined: Sun Nov 04, 2018 3:14 pm
Post
by Fonzi » Sun Jan 19, 2020 1:44 pm
Big thanks to @Jeffers76 and @ViralEye for fitting an coding in the new rear lights at today's meet!
Vwjack88
Post
by Vwjack88 » Sun Jan 19, 2020 1:46 pm
They look so much better...... one of the many jobs on my to do list
Vwjack88 on Sun Jan 19, 2020 2:09 pm, edited 2 times in total.
ViralEye
Posts: 614 Joined: Sun Nov 25, 2018 8:10 pm
Post
by ViralEye » Sun Jan 19, 2020 1:48 pm
Look soooooo much nicer
Post
by the swan fiend » Sun Jan 19, 2020 2:08 pm
Went and parked it next to some others.
Nice to meet you today @ViralEye, Fonzi and Jeffers76
BradleyB
Posts: 335 Joined: Wed Feb 20, 2019 10:23 pm
Post
by BradleyB » Sun Jan 19, 2020 2:51 pm
Were was this caddy meet ??
Fonzi
Post
by Fonzi » Sun Jan 19, 2020 4:07 pm
the swan fiend wrote: Went and parked it next to some others.
You too buddy, had a great time even if it was a bit chilly! Look forward to the next one!
Fonzi
Post
BradleyB wrote: Were was this caddy meet ??
Haydock buddy
mikenorman
Posts: 364 Joined: Thu Nov 10, 2016 10:07 pm
Post
by mikenorman » Sun Jan 19, 2020 4:09 pm
Pepsi wrote: They look awesome. Are they hard to make a set. Want to do something with mine as they just don't cut it in this dark and dingy weather.
I think the hard bit in all honesty is the painting. The pain wants to see to run and I’ve had reactions with the paint I’ve used which is annoying. Think I’m going to drop the next set into the body shop to be painted as it annoys me doing it in the back garden
mikenorman
Post
by mikenorman » Sun Jan 19, 2020 4:14 pm
@Adie66
I put them in the oven on 100degress for 5 mins and then run a flat head screwdriver around the outer edge of the channel, then find an entry point to get in behind the lens and break away the glue in from behind. Have noticed the 3pod headlights to be a bit easier to split than the 4pods, but I may have had been lucky with these as I split one of them was split within a couple of minutes!
Post
by the swan fiend » Sun Jan 19, 2020 4:38 pm
Yeah I enjoyed it @ Fonzi. Looking forward to another one..........when it’s warmer
Conorwalshmk3
Posts: 31 Joined: Fri Jan 03, 2020 7:54 pm
Post
by Conorwalshmk3 » Sun Jan 19, 2020 5:33 pm
Figured out my issues with my lighting switch not working for anything ( missing fuse ) ,after digging around online for correct fuse box and diagram I finally figured it out , also got around to putting lights on my car transporter
https://ibb.co/tbMPcP8
https://ibb.co/HnCJ2TW
