middle interior bulb to led
maxthecaddy
Post by maxthecaddy »
change the caddy cabin interior middle bulb today to a led one and noticed it stays on very dim, open the doors light comes on :D shut the door light goes off :D but stays on very dim :mad: any one had this problem :roll:
Papa Bear
Re: middle interior bulb to led
Post by Papa Bear »
Did a search and found this
“by turboDean Fri Mar 16, 2018
Then changed the interior bulds for LED.... i found with these they didn't turn fully off when the ignition was on but did when the van was locked, bit of research i found there are small leakage currents that are not enough to light a standard bulb bit will keep the LED on in a dim state, this is fixed by putting a load resistor in parallel with one of the bulb, so i soldered a 1k ohm 0.5w resistor to one of the bulb and all work well now”
Black
Marmite lover!!!
VCDS
Giddy
Post by Giddy »
O just get a decent bulbs. I have Osram led bulbs and they don't do that.
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
Papa Bear
Post by Papa Bear »
I got mine of the bay from a seller with good feedback and they worked too.
https://www.ebay.co.uk/itm/C5W-C10W-31- ... SwsEpecQRq
Black
Marmite lover!!!
VCDS
maxthecaddy
thanks for all the info guys will get some osram slung in and see how that goes👍
maxthecaddy
Papa Bear wrote: Thu Jun 18, 2020 6:57 pm Did a search and found this
thank you for this search you did for me, might come in handy👌
Papa Bear
Post by Papa Bear »
The bulbs I got are also for number plate lights so have a resistor built in so as not to cause errors threw canbus
Black
Marmite lover!!!
VCDS
Mine do this, they are spotlights mind you, planning on changing them soon.
maxthecaddy
yeah mine have the resistors in them but still stay dim, but thay was the cheap ones i put in :oops:
You might find a resistor used for error canceling is not ideal for this. Their residence will be quite high in comparison to the LED so in current flow terms there will be little or no effect.
Try a filament lamp in parallel with the LED, that should soak up the leakage current sufficiently to stop the LED illuminating to a visible level while not causing excessive heat.
maxthecaddy
THANKS DOC it works and no cost, best free info🤙🏻👍
Nice one, I'm glad I could be of assistance.
