rbu_tuninq
Post by rbu_tuninq »
I'm using morimoto d2s 5.0 .
Shrouds are 3" ...vw r32 design or something similar.
...they are all from the retrofitsource .
High beam will be on same projector with actuator .
I've got some relay adaptor wiring from the original h4 3 pin plug to : a. D2s bulb hid
b. High beam actuator
Flash should be through the relay wiring
https://ibb.co/sWZXstr
If low beam voltage is missing... on flash it will power both....low beam and actuator.
Kaddyken
Post by Kaddyken »
Our ex BG van has only done 36,000 miles but it's now 5 years old so yesterday for peace of mind, got the timing belt changed at our local garage. They also changed the water pump and gave it an oil & filter change. Drained the bank balance though :shock: :shock:
C Chis
Post by C Chis »
Fitted my colour coded R32 style bumper
Just need to sort out the lights, handle and badges now!
Katiecaddy
Post by Katiecaddy »
@c chis loving that bumper it looks spot on.
C Chis
Post by C Chis »
[mention]Katiecaddy [/mention] , cheers! It’s starting to come together now!
thecolourpurple
Post by thecolourpurple »
@C Chis . That twin pipe looking good there lad
C Chis
Post by C Chis »
[mention]thecolourpurple [/mention] cheers buddy, one of my better buys
thecolourpurple
Van coming on a treat
Sean1066
Post by Sean1066 »
Wasn’t done today but in the week.
Better photo in the day light
Caddy maxi 3.2 VR6 EX BG
My build thread
Pepsi
Post by Pepsi »
@ C Chris @Sean1066
Both the rear bumpers looking amazing.
Ripley55
Post by Ripley55 »
You’ve got to love Quad pipes 👍😂😂😂
C Chis
Post by C Chis »
New rear and LED number plate lights fitted and coded in Image
GtiAde
Post by GtiAde »
Upgraded my wobble blocks to add a bit of colour and to match the Bilstein’s
At the same time, the annual copper grease the spare wheel carrier bolts.
Katiecaddy
@ C Chis what led number plate bulbs did you use?
The wobble blocks look good in anodised blue, did you make them yourself?
C Chis
Post by C Chis »
[mention]Katiecaddy [/mention] I went for the ones from Travelinlite.
These ones...
https://travelinlite-transporters.co.u ... ight-units
Straight fit, had to bend the contacts out a little as per the instructions. Good value too, £10 for the pair.
