Reflex Silver Caddy (66)
gixxerjim
Re: Reflex Silver Caddy (66)
Post by gixxerjim »
Would be good if a good top box could be printed.
Plenty in here would buy one!
ToiletTFSI
Post by ToiletTFSI »
@Dav02
If you sand the top smooth, you could either heat the surface equally and press a texturised mould onto it to give the look. Or equally a very light skin of plastic filler on the the top after it’s been keyed and then press the texturised mould.
Think there is a kit that you can make moulds from existing surfaces - the pass side where the airbag or prob be a large enough area to do this.
Reason: removed quote
Dav02
Post by Dav02 »
Interesting, I’ll look into it once we get the final build sorted.
Build Thread
Dav02
Post by Dav02 »
1st prototype of top box fill in.
Printed in 3 parts. Lets us place in 1 piece at a time to see where clips line up.
After a few cuts to test fit I’ve got it to go in. Will need to make some amendments to the design to get the fit correct.
Build Thread
Giddy
Post by Giddy »
That looks promising, well done.
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
Post by Stedlocks »
Brilliant start👍
ToiletTFSI
very nice
Simon_B
Post by Simon_B »
Hi mate
Can you remember what glue you used for your door card trims?
Cheers.
Mk4 Highline 2.0 TDI.
Dav02
Post by Dav02 »
I plastic welded them back in using a soldering iron. There should be enough from the door cards themselves to re glue back in place once the separate parts are removed.
However for any tabs that didn’t, I had some ABS plastic rods to add extra support.
Glue for the cloth was just the standard trim adhesive
Build Thread
Simon_B
Post by Simon_B »
Cool,
I've just got hold of some mk7 door cards and removed the handles.
Also purchased some plastic welding rods too.
May go with faux suede as I've used it before and was reasonably close to alcantara.
Thanks.
Dav02
Post by Dav02 »
Version 2 of dash top cover.
Still quite a few amendments to be made. So hopefully next one shouldn’t be far away.
Build Thread
Simon_B
Post by Simon_B »
Looking good.
Jabba
Post by Jabba »
Dav02 wrote: Fri Apr 29, 2022 12:30 pm Onto the next one.
Footwell lighting.
Purchased from Stan the Man.
Red ambient lighting while driving, white light when stopped/doors open etc.
The new lights and loom
Original wiring loom out
Wiring in
Finished (after some VCDS coding)
Sorry for the photo spam :shock:
Anyone know if this will work for a mk5 caddy had looking to do this to mine
Cheifshagger
Post by Cheifshagger »
Would love this footwell kit for my mk 3 maxi. If who ever is putting the kits together please pm me. I cant pm yet 😥
Dav02
Post by Dav02 »
Have you requested access via this thread
https://www.caddy2k.com/forum/viewtopic.php?t=31039
Sorry Jabba I've no idea on the mk5 model
Build Thread
