- DaanBogers
Stripped the whole back of the van including bulkhead and headliner making it ready for some sound isolation and carpeting
Garycloona
Fitted Rocco dash pod gauges to my mk3! well happy with them!
- Bahnstormer
Noticed that the van has started doing something odd when I lock it - usually it'll beep once when it's locked, and beep twice when unlocked. Today, it's either not beeping at all and about 15-20 seconds later the alarm starts sounding or, it'll lock, then beep once about 10 seconds later (the alarm doesn't sound if it does this). Did a bit of digging on here and saw lots of posts about the high level brake light leaking, so decided to start there - low and behold, two different types of screw holding it in (barely though, they were too small to actually tighten properly). So, took them out, removed the light, applied a little sealant to the gasket and re-fitted it with decent screws. By the time I'd done that it was dark, so tomorrow I'll pull the mechanism out of the door and see if it's full of water.
lewispatt
Machine polished today, looks more like a 2 day job.
2010 Caddy SDI newbie.
- DaanBogers
Ive placed some cables for my audio setup. All speakers will have their own channel and I'm adding a subwoofer and 2 extra speakers in the bulkhead.
Still waiting for some extra Dodomat sheets as.
Also routed the positive cable to the enginebay, still need to connect it to the battery.
- DaanBogers
I've removed the wheel arches this afternoon as I know some dirt and sand may get stuck up there. This really is a design flaw if you ask me.
The amount of sand, even wet sand is ridiculous.
To prevent this from happening in the future I've 3D printed some caps to fill up the gaps in the cowl.
- Bahnstormer
Fitted and coded my new MFSW . Now I just need to buy the interface for the stereo controls and I can call that little bit done.
Also found the issue with the alarm/central locking - it was water pooling in the lower latch "well" on the big barn door. All dried out, greased and working fine again
- Damo2k
Hi mate nice job...
I'm in process of this myself could u tell me what's parts are needed for this retro..
So far have steering wheel airbag and wiring loom..any help appreciated.
- Bahnstormer
Parts-wise that's probably about it, you'd just need to check which SWCM you have fitted. Check out Doc's guide https://www.caddy2k.com/forum/viewtopic.php?t=38600, it's what I used to work out what was needed (plus a confirmation from Doc
- Damo2k
Thanks mate.yes have vcds so will do a bit of digging..and of course a confirmation from the main man @doc..
Graanddd
Fitted a Touran dash
- DaanBogers
Routed the cable for the rear view camera.
I didn't use the included cable that came with the camera as this cable is to thin. Also with this cable I can make it exactly to lenght.
Only needs coding in. Hopefully it will be easy
Bluemooner
I've gone half with my son on an ex BG caddy maxi to kit out as a camper .. lovely and clean but stunk of horses .now I do like horses but , we've stripped everything out ready for washing down , disinfecting and look at getting it sprayed ..plenty of pics heading your way ..and probably plenty of questions..I have reduced the van weight abit with taking out all the redundant BG wiring
Sent from my Pixel 6 using Tapatalk
- Bahnstormer
Used it to rescue a stuck Mercedes Viano from a muddy field. Handled it with no issues
Bluemooner
Weighed it in and paid for a 2 week holiday in Spain
