Daggz68
Post by Daggz68 »
Remapped. Drives much nicer
Bluemooner
Post by Bluemooner »
What engine is it and what's the difference? ..
..my lad is pondering getting his done
Sent from my Pixel 6 using Tapatalk
Daggz68
Post by Daggz68 »
1.9bls. 103 to roughly 140
Makes quite a big difference
Bluemooner
I'll not tell him that
leroy
Post by leroy »
on the advice of the forum i removed my spare wheel holder bolts and cleaned and greased them.
it was a proper mission that involved loads of wd40 and a 2 foot breaker bar :lol:
thanks for the tip :)
rickoo
Engine size/power: 2.0 CNG (107bhp)
Post by rickoo »
Sharkster wrote: Tue Nov 29, 2022 1:07 pm Finally changed the vinyl grill strip from red to blue.Image
the blue stripe adhesive? did you make it yourself? is it weather resistant?
thanks
Pacor
Post by Pacor »
Upgraded the pedals and foot rest.
Bluemooner
Pacor wrote:Upgraded the pedals and foot rest.
Look great ..do they cover the existing..if so where do you get those from ?
Pacor
Post by Pacor »
Yep just covers the original.
Accelerator pedal clips on and is a bit fiddly.
Got from Aliexpress
Foot rest just needs removing, drill couple of holes and bolts on.
Got from creation motorsports listed for Yeti
https://creationsmotorsport.com/footres ... r0033.html
Bluemooner
Great 👍..might have a look at those
J999YYL
Post by J999YYL »
Fitted front Mk2 heated TT seats on touran bases😎
lewisday66
Post by lewisday66 »
I fitted a set of cruise/mfd stalks, 30 pounds listed from a skoda fabia! just need to get them coded in now...
Sent from my SM-S908B using Tapatalk
Pacor
Post by Pacor »
Fitted the W8 interior light upgrade with LED bulbs finally.
Some minor adjustments needed but fairly straight forward.
Red LEDs a bit on the dim side… think I need to have a look at it doesn’t seem right…
m-racer
Post by m-racer »
I put in a rns510 yesterday. Actually i am dealing with the phone module (fse premium in german). :D
I do have a passat B7 2012 for all the parts, i would like to change the steering wheel aswell.
Dizzy Dee
Post by Dizzy Dee »
Hi All,
Fairly recent owner of a Caddy, I have a Maxi Life 2011.
My only job today apart from avoiding the rain was to reconnect the rear ABs sensor, after forgetting it when I changed the rear pads on Monday.
Still working through the demons that came with the van, otherwise enjoying the experience
ATB
DD
