Oblakov
I raplace plastic licence plate holder for inox one
Added a Mains Hook-up
As mine is a WAV conversion I have a handy entry route through a rubber edge strip.
Imprintx
DW2207
@petrev, a nice tidy safe socket setup you have done there buddy
Thanks.
Wanted something less bulky compared to C-Form CEE 16A std. blue plug.
Found the Weipu SP21 range - 3 pin rated at 30A and IP 68, so perfect.
- DeanWhit
Decided pop up to a car show with the van and spotted this.
- Bahnstormer
Found some free shelving units on FB marketplace
. Made a start on re-purposing them in the van.
Hmm ?
What's that socket for ? (left hand side rear quarter panel) .
Fitted a 7 way relay and a mini 7-pin trailer lighting socket.
Weipu SP21 - 7 pin this time.
- Handyandy
Give the van a good clean today and thought I'd put the 2k stickers on 1 out of 3 wasn't bad the other 2 wouldn't come away from the backing so the spacing got messed up trying to transfer it to the clear plastic
Sent from my SM-A125F using Tapatalk
Startline
A detailed clean and wax for my 2011 Startline:
DW2207
@startline, that's a nice clean stock example you have there mate
- Handyandy
@startline finally another caddy same colour as mine I don't see many of them about
You have a nice clean one there
Startline
Thanks Handyandy, yes, it's rare to see another Caddy in Beluga Blue. I'd seen your build thread, but hadn't twigged the colour - easy to confuse with British Gas Cyan in photos, much more obvious in the flesh. Glad you're up and running again after your recent engine woes.
- Handyandy
@startline cheers yes all back on the road now I was told that the colour was quite rare just after I bought it 5 years ago and only seen a handful since
