Engine cover difference
clewis1878
Re: Engine cover difference
@Katiecaddy
Hi Katie, did you find any further info for your engine cover? I've got a 2015 mk4 caddy maxi with the 1.6 tdi CAYD engine. Wondering if you had any joy on the part number?
Thanks Ciaran
Thanks Ciaran
Reason: removed quote added username tag
Omanvanman
I have a 65 plate mk4 maxi 1.6TDI and I’m also after the part numbers that fit for the engine cover and bottom tray? Thanks
VW Caddy Maxi MK4 1.6 102 - Member of the ex British Gas fleet van society
DaniPC
I like it, is there acoustic improvement by installing engine cover?
Best regards,
DaniPC
Best regards,
DaniPC
DaniPC
ex 1983 Renault 5 Copa (Alpine Turbo) (110 hp)
ex 1990 Opel Vectra GT (112 hp)
ex 1999 Seat Toledo TDI (90 hp)
ex 2005 Seat Leon FR TDI (150 hp)
ex 2005 Seat Leon Cupra R (225 hp, TLR Stage 1+, 268 hp)
ex 2013 Volkswagen Caddy TDI (102 hp, TLR Stage 1+, 135 hp aprox.)
2013 Volkswagen Caddy 30 edition TDI DSG (170 hp)
- Gianfry
Does anyone know if there is a cover also for petrol version?
Caddy Maxi 1.4 TGI - 2017
Expelec
- Gianfry
Dave2022
Is your engine ad blue? Does it even matter? Ha I have a mk4 1.6 with ad blue and totally not sure if it matters. Loads of those Seat covers you’ve mentioned but none specifically for caddy for sale
Reason: removed part of quote
Poffe
Fitted my new(used) engine cover today! Like a glove!
Bought Ball head bolt and O-ring new from local VW-dealer with part numbers as above. Thank you for this!
fuzzydunlop
I’ve got the cover and the ball-head posts are on their way. What do you need the O-ring for?
Poffe
O-Ring is for mounting around oil cap. If you spill some oil when filling in the oil cap it will stay up on the small surface around the oil cap and not drip down on engine block, cables and what not.
fuzzydunlop
Thank you. Good to know. Especially having just cleaned the top of the engine!
Poffe
Now that I have secured that the oil won’t drop I might just give my engine a good scrub
Skickat från min iPhone med Tapatalk
Norcot
Check the engine code / type my 2015 1.6 is a CAYD, I bought a Seat cover for CAY 1.6 tdi engine and like others it’s perfect fit. Just need to buy two screw in ball / studs which screw in and the cover clips onto
