I am asking you about replacing the meter. I currently have a basic computer with my 2011 Caddy, I would like to replace it with a slightly more advanced one. I have VCDS and I'm fairly familiar with it, but how should the replacement be carried out so that there are no accidents? Thank you in advance for your help.
http://foto-hosting.pl/img/20/ae/02/20a ... 9bf7f.jpeg
http://foto-hosting.pl/img/b5/75/55/b57 ... cbd68.jpeg
Wymiana licznika / komputera na bardziej rozbudowany
Re: Wymiana licznika / komputera na bardziej rozbudowany
Welcome to the forum.
You find that since the change in VW immobiliser system in 2007, VCDS just won't do what you want. You will need an alternative system which can read and write to the instrument cluster (NEC type in your case).
The equipment is expensive so you may be better off finding someone with it who can do your swap as a service.
It's good to listen to a wise man. Thank you for clarifying the topic. I'm giving up on the modification.
Where are you based? You never know there may be someone not far away who can help you.
I am in Poland, near Poznań. Of course, I will look around for people who know the subject. Although I must admit that simply switching and enabling a few options through the program will help solve the problem.
- spacewalker
masz w Pl w pyte forum VW , tourana, Golfa, skody ....... tematy o wymianie liczników przewijają się od 10 lat
wyslij mi autoscan z VCDS na major@hot.pl
