Wireing layout
Wireing layout
Hi all I need to drill into the door pillars in the rear of my maxi van it’s twin side doors and lift up tailgate and don’t want to hit the wires it has a roof lining with one light in it so without removing it I don’t know if the wires are inside any of the box sections I want to drill into thanks for any help cheers
Re: Wireing layout
Any chance of a quick pic where and which side you are looking at?
Re: Wireing layout o
Thanks for replying it’s uk passenger side all you would see from a photo is the carpeted side of the van it looks like the carpeting has been applied over the screws
Re: Wireing layout
Passenger side of mine I’m 90% sure the top light runs over the slide door and dow the a pilar
Re: Wireing layout
Thanks mate photo is spot on it looks like most of the wires are low down mine has wires for the tailgate up top so I should have no problem drilling the rear pillar and I can use the rear seatbelt mounting top bolt hole for the front as I have removed the seats and fitted a bulkhead cheers.
Re: Wireing layout
No probs
