davoc220
Post by davoc220 »
@STP
Yes, ignition was off the full time, have a feeling I haven’t wired the plugs correctly, on the drivers side there’s 3 wires, on the oassengers theres 5 on the seat sides, on the body loom there’s 3 on the caddy
Flog_TSC
Post by Flog_TSC »
Removed seats and center console gave it all a clean and general tidy as previous owner hadn’t bolted everything up quite right
Also fitted a compact sub under the passenger seat
mirogo
Post by mirogo »
Good morning everyone,
Last weekend I insulated my floor in the cabin and retrofitted a Touran Mk1 carpet, next step is a touran center console with armrest and then door insulation include new speaker set.
Bienie
Post by Bienie »
gave her a good deep wash. well needed after 2 weeks in Norway!Image
STP
Post by STP »
That looks nice, I started looking for a Touran front carpet set on eBay but people are asking £100 for them on there. Bloody cheeky.
Marcelorider
Post by Marcelorider »
I’ll be quite honest I haven’t read all the posts, are there any recommendations in terms of must have mods for the caddy?
son of eevil
Post by son of eevil »
Pulled the EGR and throttle bottle and that pip that connects both to the intake manifold
Gave both a good clean up of all the built up sludge.
Am debating pulling the intake manifold so that I can clean it too... But it's so many new gaskets I need to buy.....
About 3 EGR gaskets, exhaust gasket, intake gasket for like $200 worth of gaskets...
I REALLY want to clean it... But also, I don't want to spend $200 on gaskets when I am already 2K deep in parts and refurbishment....
STP
Post by STP »
The entire intake will be choked too. I wondered about the cleaning system that Edd China was advocating, if it could get rid of the amount of sludge built up. I've personally seen Citroen HDi engines stripped down and the intake runners had been reduced from 38mm down to about 15mm due to carbon sludge build up and it's a wonder the engine even runs at that point.
Flog_TSC
Post by Flog_TSC »
Mapped the maxi now actually flies im well
Impressed with the little 105 engine not sure what bho it is now but all good
Couldn’t get into the security using vids to take the limiter off tho not sure why
son of eevil
Flog_TSC wrote: Fri Oct 03, 2025 6:31 am Mapped the maxi now actually flies im well
Big difference then?
Any change to the fuel efficiency?
son of eevil
Pulled the intake, exhaust, turbo, gearbox and DMF off.
Lois
Post by Lois »
Today I installed a leather steering wheel on my Caddy and welded a bracket for a Lagun table.
Caddy Rob
Post by Caddy Rob »
Today I took the shocks, steering knuckles and driveshafts of the touran, had to take them off together as I couldn’t undo the driveshaft bolts😡.
Only got one side off of the caddy, what a f#€king ball ache. The three bolts under wiper motor are a bitch to get at!!
Had to split the bolt on the drop link to get it off.
Will have a go at other one in the morning and get the touran ones on.
After that think all the mechanical bits are done💪🏼 and I’ll be moving on to the electrics!
Jack-uzii
Post by Jack-uzii »
Today i removed the bulkhead, attempted to fit carplay but ultimately was not impressed with the quality of the screen so returned it (any recommendations for a mk3 caddy?) then sat in the back and enjoyed the fact i can chill in my van
Caddy Rob
Post by Caddy Rob »
Today I mainly swore at the caddy.
