MK4 maxi Life Roof Lining Removal
gt900uk
Post by gt900uk »
Any guides about in how to do this. Figured alot of it out but it's seems to still be fixed with hidden clips around the roof.
Giddy
Re: MK4 maxi Life Roof Lining Removal
Post by Giddy »
Which part of roof lining you want to remove? The one inside the cabin?
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
MikeH460
Post by MikeH460 »
Sussed it out today & all sorted, not too challenging once you understand the design of the retaining clips
This worked for MK4 without the roof side pockets
1 remove seat belt upper bolts
2 remove plastics behind seatbelts, loosening fronts will make taking top out easier
3 remove grab handles, visors
4 remove rear small headlining, a few expander plugs & tailgate seal hold it
5 remove centre light using body panel tool, there’s a steel edge in the headlining that the light is clipped into
6 remove front internal light cover, remove screws that hold the light fitting to roof
7 remove alarm sensor ditto to centre light
8 loosen the headlining all the way around its lowest edge & free it from any metalwork protrusions
9 gently pull the whole headlining from the rear & it will slide back, may need a bit of freeing/wiggling
10 gently lower headlining under control if possible with help in front seats so it doesn’t drop
11 2 orange retaining straps on very rear 2 clips will hold up the back of the linining
12 these are held in with 2 steel clips that can be squeezed & removed from bodywork to allow complete lowering & removal
13 9 clips should stay in roof/body that slide into slots on the headlining…will make sense when you see them
Will load pics once I learn how
gt900uk
Post by gt900uk »
Forgot to come back earlier to say thanks, got it off as much as needed to run a wire through for the rear camera. Just need to finish off the wiring now.
juliang71
Post by juliang71 »
I've been meaning to reply to this one, what was the purpose of you removing it and what's like underneath? Any photo's at all?
When I removed the side plastics out of mine to add some insulation and then did it all again later this year I was thinking do I just have a go and remove the roof lining as well. If there is just some small pieces of sound deadening I'm tempted to do this.
juliang71
Post by juliang71 »
I should have read the last post ... that would have helped :lol:
Wire for the camera ... that's another one of my jobs on the never ending list of jobs.
Ellis667
Post by Ellis667 »
juliang71 wrote: Fri Dec 19, 2025 4:57 pm I should have read the last post ... that would have helped :lol:
Have fun getting the wire through the tailgate rubber!
