Cabin light issue fix
Goosha123
Hi, the connector clip from middle cabin light has been clipped and it’s throwing up a light on the dash, I’ve ordered the housing and terminals for it, only issue is the wires been clipped too short to reach it, any ideas for solution?
STP
Re: Cabin light issue fix
Is this the front cabin overhead or rear one? Ideally you would need to take down the overhead tray then lengthen the wires using solder and heat shrink.
Goosha123
It’s the rear one, I’ve ordered some 1mm single core and I’m gonna try that
