Removed front bumper to do a test fit ...
Before - Old Water Tank
Test Fit - New Tank and Webasto + Checking to see the best way to route my modified water pipes !
liamg20025
Post by liamg20025 »
Papa Bear wrote: Sat Aug 22, 2020 10:04 pm Image
These looks great, is it easy enough to swap out the LED?
Cheers,
Liam
BG VW Caddy Maxi 1.6tdi 64plate - Currently converting to a camper
Have a look in Papa Bear's Hampshire Caddy thread and you may find all your answers ...
Lots of little LEDs
Finally managed to get the fuel pipe through the tunnel
Used it to pull the pump loom and split tube protection through.
Fitted everything in place and seems to fit.
Do some electrical testing tomorrow ...
Konkers
Post by Konkers »
Spent my workday fitting my heated seat wiring harness supplied by stan the man, also stuck down some insulation in the footwells. Forgot to take more pictures ImageImage
Putting back the front bumper after fitting Webasto.
Before I did I fitted a honeycomb mesh to hide the silvery radiator from view
Outside
Inside
I also (finally) fitted my old Blaupunkt Titanium Dome Tweeters from my old 1982 speakers !
They just sound so great I have moved them to each new car in turn - Jetta 82, Jetta 89, T4 2002, Caddy 2018
:D
DeanWhit
Post by DeanWhit »
Fancied something different but This is going to take some getting used to. Image
envycommercial
Post by envycommercial »
Fitted my side bars
That blue van is a nice looking van
@DeanWhit bumper looks proper mate
Post by stu_b »
surely thats a custom bumper..... whats it off
looks sick :)
Looks like a mk8 golf R, might be wrong tho...
DeanWhit
Post by DeanWhit »
Thanks for the positivity lads. It’s a golf mk8 clubsport. There are some more bits to go with it so hoping it looks better in a week or.
Looks good Dean.
TheGee
Post by TheGee »
I blackened out the rear windows and added security plates inside Image
Striving for the perfect excess
Instagram @g_giotec
New build thread >>HERE<<
mikenorman
Post by mikenorman »
Couple of before and afters on a recent purchase.
I bought the van not in the best shape but it had a strong engine, although fairly high miles it drives like new.
Before
NowImage
Mods done
18” smoothies
Respray and new front bumper
Rebuilt headlights, black inserts and halos fitted which are wired into ignition to work as drl
Mk4 rear light conversion
Carpeted the rear
New number plates
Lowered on stance coilovers
New rear black vw badge
Just waiting on some new side repeaters to arrive and getting a side rail cover which I think will make it complete, but probably not Image
I done all the work apart from the paint and fitting the suspension.
