Page 1 of 2
Side rail cover
Posted: Wed Mar 02, 2016 7:13 am
by owen12345
Anyone know the best/cheapest place to get just the cover from. Don't a guy on here do them ? Thanks
Re: Side rail cover
Posted: Wed Mar 02, 2016 8:42 am
by Lembot85
I'm in the same boat mate I'm not paying over £100 for one
Re: Side rail cover
Posted: Wed Mar 02, 2016 9:20 am
by Ash08
TPS will be your cheapest option then depending on your skillset paint and fit yourself.
Re: Side rail cover
Posted: Wed Mar 02, 2016 2:13 pm
by chris855
Ash08 wrote:TPS will be your cheapest option then depending on your skillset paint and fit yourself.
Do you know the part number for TPS? Tried a search and can't find it.
Re: Side rail cover
Posted: Wed Mar 02, 2016 4:53 pm
by tonyhill
Is there a "how to" on fitting these rail covers? Are they simply bolt on, or is there more involved??
Re: Side rail cover
Posted: Wed Mar 02, 2016 6:25 pm
by turbodcaddy
There's a little to it you'll need to make a bracket that sits inside of the sliding door so it can be secured and the back is just a push clip you can use the clip that you take off the plastic piece if you still have it I do have a template for this bracket
Re: Side rail cover
Posted: Wed Mar 02, 2016 8:40 pm
by Decinick
You don't always need to make the bracket, usually 09 plate onwards already have them, Reflex Auto Design sell a bracket that is made for it if you can't make one.
As already stated TPS or VW for the cover, part number is in the useful part numbers thread, about £35 I think.
Re: Side rail cover
Posted: Thu Mar 03, 2016 12:23 am
by tonyhill
Do you have to change the rail aswell..? Only reason I ask is because on RAD's website it lists the package as 'rail, cover and bracket'.
Re: Side rail cover
Posted: Thu Mar 03, 2016 8:32 am
by rftrft
I don't think you have to change the rail, I hope not as I am hoping to fit one soon as I think these look so much better. Mine is a 2010 pre face lift so I am hoping it comes with bracket.
Re: Side rail cover
Posted: Thu Mar 03, 2016 8:37 am
by Barbel330
The reason people change the rails is because they have clips on them for the cover to clip to, your original won't. I've seen people on here say that they've put a blob of adhesive on the rails instead but I've no experience of that. I don't think the rails are too much money to buy?
Re: Side rail cover
Posted: Thu Mar 03, 2016 10:27 am
by Ash08
i cut and bent some steel (around 2-3mm thick) you need to bend it into a L - V Shape then i used the original back clip and a blob of adhesive, took me about an hour to perfect it but saved me monies :D i bought my rail from the local VW dealer :oops: , think it was £43
2K0843795B Left Rail Cover
2K0843796B Right Rail Cover
7H0843658A Clip For back End of Rail
Re: Side rail cover
Posted: Thu Mar 03, 2016 10:29 am
by Lembot85
Cheers mate think I'll give that a go!
Re: Side rail cover
Posted: Thu Mar 03, 2016 6:51 pm
by chris855
Just what i wanted to know. Cheers
Re: Side rail cover
Posted: Sun Mar 06, 2016 9:02 pm
by harrycrumb
Ash08 wrote:i cut and bent some steel (around 2-3mm thick) you need to bend it into a L - V Shape then i used the original back clip and a blob of adhesive, took me about an hour to perfect it but saved me monies :D i bought my rail from the local VW dealer :oops: , think it was £43
Perfect, this is going to be my 1st external mod, then onto the handles, and I have a TPS up the road from my work too
Re: Side rail cover
Posted: Tue Dec 05, 2023 8:34 am
by Poffe
Is it the same numbers for Side rail covers to a Maxi?
