Under trays
Celticrsmith
Under trays
Post by Celticrsmith »
I’m after an under tray as nothing more wretching than hearing stones, pot holes and general road debris (usually roadkill!) slamming off the underside of the caddy!
So, I understand that the part number is 1K0 825 237 K however, I’d guess tourans fit and also possibly a mk5 golf? Just looking to broaden my search horizons....
Caddyluv
Re: Under trays
Post by Caddyluv »
Mine was £75 new from vw.
LeeH
Re: Under trays
Post by LeeH »
It’s s good mod, well worth doing along with the engine cover. It’s dampens the noise a little.
Celticrsmith
Re: Under trays
Do you get an engine cover for the sdi? :roll:
Bionicman
Re: Under trays
Post by Bionicman »
Celticrsmith wrote: Sun Jul 01, 2018 4:34 pm Do you get an engine cover for the sdi? :roll:
Yes you can get an engine cover for a SDI. Second hand for about £20.00 - £30.00 depending on condition.
Celticrsmith
Re: Under trays
Is it the same cover as a mk5 golf sdi? :roll:
Bionicman
Re: Under trays
Post by Bionicman »
Celticrsmith wrote: Mon Jul 02, 2018 6:33 am Is it the same cover as a mk5 golf sdi? :roll:
Yes I think the MK 5 Golf SDI use the same cover. What is your engine code and I will make sure you get the right one.
Celticrsmith
Re: Under trays
Dunno mate, where will I find the code?
Bionicman
Re: Under trays
Post by Bionicman »
Celticrsmith wrote: Mon Jul 02, 2018 9:06 pm Dunno mate, where will I find the code?
Owners service manual/handbook at the front, sticker on cambelt cover or sometimes on the sticker attached to the drivers door pillar just below the catch.
Celticrsmith
Re: Under trays
Thanks bud, I’ll have a look
nodeward
Re: Under trays
Post by nodeward »
also interested in this, I have a 1.6tdi and I think they look odd without a cover, I was hoping there would be another I could use
Basil
Re: Under trays
Post by Basil »
Hi
I'd be interested in the part numbers needed for under tray and engine cover for CAYD, thanks. :thumbs up:
Bionicman
Re: Under trays
Post by Bionicman »
Hi Basil,
Go to page 7 and find the topic on engine covers. All the part numbers required for your CAYD type engine are listed a bit further down that page by a post reply by bluecaddymaxi.
As regarding the under tray/noise insulation the part number is 1K0 825 237 AG. The last two letters could also end in AE or AC but will fit the same.
Basil
Re: Under trays
Post by Basil »
Thanks Bionicman :) much appreciated.
shanky887614
Re: Under trays
Post by shanky887614 »
if your concerned about bottoming out you can buy an aftermarket steel/ali sump guard
