I'm trying to locate the alternator pre fuse connection to the bonnet fuse box . Fuse box locations for the 2016 are hard to come by and not consistent.
Can anyone confirm which location it is?
https://ibb.co/bRdvRQGb image of my fuse box
Based of this fuse box diagram it suggests the far left connection but on mine that doesn't seem to match up https://www.startmycar.com/gb/volkswage ... sebox/2010
2.0L TDI 2016 alternator fuse box location
pebs
Re: 2.0L TDI 2016 alternator fuse box location
Based on the VW diagrams I have it is the far left "B"
STP
Yep. Far left B is Alternator and next one C is power steering motor.
Not individually replaceable, you have to change that whole module. Under £20 from Amazon. I bought mine there and its very good quality. No issues months later.
https://amzn.eu/d/dFuYxD7
Btw testing these semiconductor fuses with a meter won't work, when the main live is connected, they all seem ok until you disconnect the strip and test off the car, then you see which ones are blown.
