mkvanman
Overhead shelf is easy to take down.
Geraout
.... been messing with VCDS when I got home from work.
Changed lane change indicator flashes to 5.
Enabled digital speed on dash.
Replaced the kph display with temperature.
Enabled needle sweep on ignition on.
I'll see what else I can find to play with..
pushpullmover
Having shown off my Limo tinting, which I had done yesterday, to numerous fans I decide to use my garden metal gatepost as a sliding rear door handle remover. It works perfectly as a door handle remover - I was gutted!
- Adam87
Any info on how you did the speedo? I can't get the digital speedo upGeraout wrote:.... been messing with VCDS when I got home from work.
- horace01
Oh no!! I feel your pain. I'm currently having a rear door mishap fixed.
Hayden
If only I knew how to do these things... Not all that confident with vcds as yet... Is there anywhere on the forum or online that has information of making changes like this?Geraout wrote:.... been messing with VCDS when I got home from work.
Thanks, Hayden
- Bohall
Van Nicholas titanium, amazing! I have one myselfS.w.blackwell wrote:Here you go.
- Bohall
19's Speedlines? Colour and vinyl work well. You should try and get along to the Monthly burger meet the guys on AutoStadt.ie have in Stillorgan if you're around the Dublin area, 1st Tueaday of every month. Caddy looks class.Convw wrote:Speedlines and vmaxx fitted.
- anoneamus
Is this on a stock Caddy cluster? I've seen it on a Golf 7 in VCDS, but not Caddy.Geraout wrote:.... been messing with VCDS when I got home from work.
Facelift caddy clusters may or may not have this needle sweep option available in VCDS but they all can do it. Just not always available with VCDS.
S.w.blackwell
Coat hanger fitted.
Geraout
Yes - stock cluster 2014 C20.anoneamus wrote: Is this on a stock Caddy cluster? I've seen it on a Golf 7 in VCDS, but not Caddy.
It took me a while to work out that its not "staging" that needs to be enabled (this just returns an out of range error) but "indicator celebration".
I.D.S.
I had to change from mid to highline clocks to activate this.
rsjohn
mkvanman
Looking nice will you get it all done for next weekend.
