mkvanman
Post by mkvanman »
Overhead shelf is easy to take down.
Geraout
Post by Geraout »
.... been messing with VCDS when I got home from work.
Changed lane change indicator flashes to 5.
Enabled digital speed on dash.
Replaced the kph display with temperature.
Enabled needle sweep on ignition on.
I'll see what else I can find to play with..
pushpullmover
Post by pushpullmover »
Having shown off my Limo tinting, which I had done yesterday, to numerous fans I decide to use my garden metal gatepost as a sliding rear door handle remover. It works perfectly as a door handle remover - I was gutted! :evil: :evil:
Adam87
Post by Adam87 »
Geraout wrote:.... been messing with VCDS when I got home from work.
Any info on how you did the speedo? I can't get the digital speedo up
horace01
Post by horace01 »
Oh no!! I feel your pain. I'm currently having a rear door mishap fixed.
Hayden
Post by Hayden »
If only I knew how to do these things... Not all that confident with vcds as yet... Is there anywhere on the forum or online that has information of making changes like this?
Thanks, Hayden
Bohall
Post by Bohall »
S.w.blackwell wrote:Here you go.
Van Nicholas titanium, amazing! I have one myself :D Handy way of doing the bike mounting. I have my Enduro MTB mounted but it faces the other way, uses a sea-sucker 20mill Axle mounting bracket.
Bohall
Post by Bohall »
Convw wrote:Speedlines and vmaxx fitted.
19's Speedlines? Colour and vinyl work well. You should try and get along to the Monthly burger meet the guys on AutoStadt.ie have in Stillorgan if you're around the Dublin area, 1st Tueaday of every month. Caddy looks class.
anoneamus
Post by anoneamus »
Is this on a stock Caddy cluster? I've seen it on a Golf 7 in VCDS, but not Caddy.
Facelift caddy clusters may or may not have this needle sweep option available in VCDS but they all can do it. Just not always available with VCDS.
S.w.blackwell
Post by S.w.blackwell »
Coat hanger fitted.
Geraout
Post by Geraout »
anoneamus wrote: Is this on a stock Caddy cluster? I've seen it on a Golf 7 in VCDS, but not Caddy.
Yes - stock cluster 2014 C20.
It took me a while to work out that its not "staging" that needs to be enabled (this just returns an out of range error) but "indicator celebration".
I.D.S.
Post by I.D.S. »
I had to change from mid to highline clocks to activate this.
rsjohn
Post by rsjohn »
Sorted the cab section of my caddy build today, Touran dark carpet, a pair of recaro sportster cs seats, golf r steering wheel, cruise control kit, highline clocks and touran center console.
mkvanman
Post by mkvanman »
Looking nice will you get it all done for next weekend.
