Not a simple fit as the seats rails are about 15mm wider than Caddy seats.
Hi.kully12 wrote: ↑Tue Mar 27, 2018 12:33 am Hey Turbo Dean
Could you have a look at this post Ive posted on link below:
http://forum.caddy2k.com/viewtopic.php? ... 5&start=45
Would really appreciate your help if you can - Would really like to install them quickly.
I noticed your seats are almost identical
I have found out from the fourum that Stan the man is the guy to talk to about this so I have messaged him aswell
Regards
Kuldeep
No worries OEM looks better, i was just too inpatient and wanted them working in the cold weather.kully12 wrote: ↑Wed Mar 28, 2018 5:50 pm Ahh thanks for that - really appreciate it - Sounds soo simple and doable the way youve explained it
Stan the Man has also given me a reply in regards to this, I shall get back to him and see what his method is, believe he will guide me in the route of the OEM way then probably make my mind up after that.
My initial thought - as always will be to try the closest method to OEM - as long as I dont break the bank - but its for my back so I really dont want to skimp out on it as I spend alot of time in it while working
Thank you for your response, pictures and the small description you have given me doesn't sound like alot to think about and shall definitely weigh it up
Thanks, Kuldeep
Do you mean my ones? If so then yes and no. When you take the caddy seats out there is a H shaped base left bolted to the floor of the van. You can use these with a little modification to mount the GTI Seats. The only problem is that the bolt holes on the GTI seat rails are about 20mm longer front to back and about 10mm wider than the bolt holes in the frame. I did wonder if you could just take the rails or part of them off the caddy seats and put them on the GTI ones but they are different shapes and mount onto the seats different so no.sausagefingers wrote: ↑Thu Mar 29, 2018 9:00 pm Cracking pair of seats, probably my favourites, did they fit straight onto the caddy rails?
sausagefingers wrote:Thanks Matt for such a thorough reply![]()
I've been looking for some of these seats but struggling to find a good set at a decent price locally, they are either knackered or very expensive.I'm in no rush yet so fingers crossed some will turn up. Can't believe how cheap some people are picking seats up on here cos there are none where I live
