Starlight Blue Caddy Life - Mk4 2K SA - WAV + Stealth Camper for One.
Starlight Blue Caddy Life - Mk4 - WAV + Stealth Camper for One.
My Upgrades - In (approximate) Date Order as Fitted ...
01. ClimAir Wind Deflector - Smoked - From Euro Car Parts 2015+
02. ClimAir Sonniboy Privacy Shades - From Germany - Single rear window - Single shade
03. Upgrade steering wheel - DSG Paddles - From Cars-Equipment CZ with ACC Buttons (Needed to change to CCS)
04. MFSW Button change to CCS - Caddy buttons from LLLParts.co.uk Lithuania.
05. SEAT Ibiza FR front seats.
06. Engine Undertray - Dirt and noise insulation. LLLParts OEM. Fixing kit from AudiVW24
07. XENON Headlights - 35W Upgrade BEST Ever Mod (RHS RHD Hella from eBay. LHS VW from LLLParts. Ballasts, drivers, bulbs from LICHTEX.de)
08. Cherry Blossom Liquid Polish - Side protectors and other black plastic bits.
09. Door panel sound deadening and thermal insulation (+ 4Way Stretch Carpet) . Rear wheel arches, rear quarter voids, roof void.
10. Aluminium Pedal Covers - Cheap from AliX
11. Footrest plate - (Yeti) from Creation Motorsport
12. ATOTO 10.2" A6Y1021PR Android Head Unit.
13. Used heat gun to remove/repair birdsh!t marks on the bonnet.
14. Black/Smoke side repeaters. T6 modified first then later Caddy Mk4 from Travelin-Lite.
15. Touran wheels Atlanta with 205/60 R16 tyres.
16. Sink/Hob Unit and a base for a Thetford Cube (both removable with clips)
17. Passat W8 interior light unit (From AliX + tommyzooom adaptor)
18. Front and Rear Cameras from AliX - HD 600 Line Camera Boot Handle Camera
19. Blacked out front badge - Plastidip + Vinyl Logo (changed later to Plastic cover from AliX)
20. TSI Engine Cover - 04E 103 925 F and mount 04E103932C from LLLParts - OEM VW
21. Tinted Rear Lights - RHS is LHD unit for symmetry - OEM from LLLParts
22. DEZENT TD Graphite 6.50x16 5x112 ET50 - New Wheels
23. New Tyres - Goodyear Vector 4Seasons Gen-2 205/60 R16 H (92)
24. Digital Speedo Display - OBD-Eleven / VCDS Caddy2K
25. Climatic HVAC Panel Upgrade - New S/H Panel and Temp sensors. Needed extra power feed CF all other Mk4 Caddys !?!
26. Golf Mk7 Drivers Seat - 3 Door with tipping function - Mount on Caddy Comfort/Touran Base.
27. Tiguan Passenger Seat - Fold Flat - Mounted on Caddy-Mk3 Base.
28. R-Line Top Sport MFSW with Golf 7 6G0 Buttons for CCS - eBay S/H
29. LED Bulbs for W8 Interior light - Travelin-Lite
30. PDC OPS Front and Rear 8K Module - Distance Display on Android unit. How 2 Fit - Modified a kit from CZ (extra work)
31. Extra latching switches added for Front and Rear cameras (Display override function)
32. Wolfsburg Edition Hub Centre Caps. Slippery slope begins ...
33. AUX / Leisure Battery and Charger fitted into engine compartment (1.4 TSI Only)
34. LED Fog Light Bulbs - Travelin-Lite (again !)
35. Boxed in RHS Rear Wheel arch - Mounted WAECO Freezer Box. Pic
36. Storage Box RHS next to wheelarch . Pic
37. STOP/START Button Memory Function Board fitted.
38. Insulation / Condensation Grill fitted (cut to size) - Rear Quarter. From Amazon - Pics
39. VW OEM Privacy Tinted Glass in rear area. TPS / Autoglass.
40. Bragan Roof Bars. Slightly more than DST but have wings for lashing !
41. ACC - Adaptive Cruise Control - Thanks to Spacewalker for upgraded Radar and How2 - Fitting
42. Black Cover for Front Badge - Tiguan Badge on AliX
43. Black TSI Badge - AliX
44. Made Seat Base Adapter to fit YETI Rear Seat - Folds and unclips etc. Pic
45. Converted Rear Lights to Double Reversing and Double Rear Fog Lights - LEDs - How 2
46. Wolfsburg Edition Badges and Gloss Black Pillars - VW OEM from LLLParts + Vinyl Wrap Pics
47. Black Front Grill and lower grills - New Grill + Wrap and Spray . Pic
48. Tinted Rear Reflectors - VW OEM from LLLParts (also tinted high level brake light - wrap)
49. Black CADDY Name Letters - AliX
50. Wolfsburg Edition Numberplate Holders
51. Stealth Blinds - Black and White quilted reversible blinds for camping.
52. Clip In Seat/Bed base - Folds / opens for camping bed.
53. CADDY Mk5 California Window Vents - Slight modding needed - Pics
54. ACC GTI Wheel fitted thanks to Spacewalker module.
55. Removed LHS rear quarter/wheelarch cover. Carpeted LHS lower rear quarter. Fitted new board with luggage area light and switch, cig socket and vent.
56. Made a Bed-box that folds forward to make the bed and has done storage.
57. Spliced Leisure Battery Changeover feed into BCM interior light feed. Interior lights now work at anytime from aux battery and don't switch off at the whim of the BCM. Added On-Off-On change-over switch so that boot area light can be switched on with lid closed (also from aux batt option as well).
e&oe
Not done.
ASR Button - No room !
Blue needles - No skill !
PTC - Heater element in matrix - No Time !! Yet !!
Washer Fluid Level Sensor - Not yet.
Re: Starlight Blue Caddy Life - Mk4 2K SA - WAV + Stealth Camper for One.
Pix ...
Yam442
Post by Yam442 »
Loving the build I'm currently planning on converting my mk3 maxi WAV so will be following this thread 🤠👍
Decided to remove the LHS rear arch cover and make a new bed position at the rear.
Photos in reverse order (typical).
Removed cover then tidied up the wiring (a bit).
Work out where to put everything ???
Do some carpeting...
Fit some M8 rivnuts.
Make a cover board - Start fitting things.
2 days already 😮
Finished the side work.
Just need to make a new bed box ...
Started the Storage/Bed Box ...
Functionally finished.
Have to paint and edge things, and cut ventilation holes.
Camping in North Wales
Ellis667
Post by Ellis667 »
Hi mate
I'm In the process of fitting heated seats In my mk4 wav. I can get the blowers to work with my new panel. Did you have trouble with this also?
I did !!!
There is a Live feed needed extra to those as provided before.
Had to splice in an Ign switched feed, if I remember rightly ?
I discussed it somewhere ...
I'll try to find it 🤔
Here it is (at least in part)
https://caddy2k.com/forum/viewtopic.php ... 24#p390724
petrev wrote: Wed Feb 24, 2021 9:41 pm Yay !
Caddy Mk4 2018
- 3C8 907 336AE - Heated seats and 4 Buttons inc. Heated Rear Screen and Aux. Heater.
- 3C8 907 336AB - Basic Climatic
Both work, but in my case only after some extra wiring.
My Caddy has an extra Black wire that feeds a relay to switch on power to the fan control.
I added an IGN-Switched Live and spliced to the black wire.
I also added a diode in the black wire, and another in the extra feed, to prevent any back feeds if an original panel were ever to be refitted !
Seems to be working a treat.
Thanks for all the help and info from this thread and elsewhere.
:thumbsup:
How I got the info to fix the no blower issue...
https://caddy2k.com/forum/viewtopic.php ... 9&start=45
Ellis667
Post by Ellis667 »
Thank you very much. Still waiting to be approved for forum rights. I tried this the weekend. I spliced into the feed for my pioneer head unit which is powered via am ign live but still had no joy.
I used a strand of 1.5mm twin & earth. So that could have had something to do with it. The black cable your splicing into is in 20 pin plug in slot 2 isn't it?
Yes, that's it.
20 Pin Connector - Pin 2 Black Wire
T20c/2 - +VE with IGN-ON (drops to 0V after 7 seconds from IGN-OFF - Relay Clicks)
Ellis667
Post by Ellis667 »
I'll have to try again at some point, getting really frustrated with it now.
Do you happen to remeber what amp/size cable you used? Did you use a scotchlok connector or?
I soldered the new wire to the Black wire.
I also added a diode in the Black wire to prevent back feeding into the panel (should not be needed unless reverting to original panel) and have a similar diode to prevent flow from the panel to the fuse box, also probably not necessary !
Don't need much of a guage as only to throw the relay. I overdid it and used about 10A if I remember (which I don't really).
Ellis667
Post by Ellis667 »
Brilliant thank you. That might be my best option then.
