m-racer
Posts: 30 Joined: Wed Mar 01, 2023 11:24 am
Post
by m-racer » Sat Mar 11, 2023 7:29 am
I broke my antenna connector on the rns510 yesterday.
The white double plug is now only one... I put in the antenna cable and after my test I pulled it out and the center pin/thin cable broke. Now no signal anymore on this one.
Is possible to change the white connector on the rns510?
martynbruce
Posts: 32 Joined: Thu Feb 09, 2023 9:02 am
Post
by martynbruce » Sat Mar 11, 2023 4:42 pm
I managed to do a clutch pedal delete again lol bloody clutch master
Van Life
Posts: 48 Joined: Fri Feb 17, 2023 11:44 pm
Post
by Van Life » Sun Mar 12, 2023 9:11 am
Woke up to this
this isn't what I envisaged my first mod to be!
Sent from my SM-A536B using Tapatalk
DaanBogers
Posts: 18 Joined: Wed Dec 21, 2022 12:53 am
Post
by DaanBogers » Sun Mar 12, 2023 11:05 am
Added bonnet isolation, a MK7 battery box, and engine cover today
Posts: 2302 Joined: Sun Apr 26, 2015 1:41 pm
Post
by petrev » Sun Mar 12, 2023 3:26 pm
More rationalisation of existing wiring and making new wiring ...
and making adjustments to fuse boxes ...
and ...
CarlH
Posts: 8 Joined: Thu Mar 09, 2023 1:07 pm
Post
by CarlH » Mon Mar 13, 2023 4:10 pm
First real work started on camper conversion. Stripped out old panels, full clean out and wash down then sound deadening on arches and side panels along with some foil lined insulation on side panels and in any gap I could get it into. Happy with progress, long way to go but absolutely loved being out there doing it!!
3rdLeg
Posts: 131 Joined: Mon May 10, 2021 1:43 am
Post
by 3rdLeg » Mon Mar 13, 2023 4:19 pm
@CarlH
You doing a build thread?
Enjoy following a camper build and see people’s different approaches to it
CarlH
Post
by CarlH » Mon Mar 13, 2023 4:22 pm
@3rdLeg
Haven’t started one mate, still new to the forum and not sure yet about posing pics etc.
Will try and get my head round it tonight
3rdLeg
Post
by 3rdLeg » Mon Mar 13, 2023 4:48 pm
Nice one I’ll keep an eye out
gjseb
Posts: 340 Joined: Thu Feb 14, 2013 3:36 pm
Post
by gjseb » Mon Mar 13, 2023 6:23 pm
DaanBogers wrote: ↑ Sun Mar 12, 2023 11:05 am
Does mk7 battery cover and engine cover fit on mk4 caddy
Nickdsg
Posts: 2 Joined: Tue Mar 14, 2023 7:58 am
Post
by Nickdsg » Tue Mar 14, 2023 8:04 am
Ordered head light tinting film and drls.
m-racer
Post
by m-racer » Wed Mar 15, 2023 1:03 am
I am going to repair the cable from the hood latch. I filled up the oil and after that the light didn't turn off. I tested the wipers when the hood is open and it works. That means that the system does not know that the hood is open.
But before buying a new cable, I am trying to repair it. Maybe I can fix it for cheap.
Post
by petrev » Fri Mar 17, 2023 3:38 pm
First bit of a modified Fiamma Carry Bike Caddy
Bahnstormer
Posts: 428 Joined: Mon Apr 25, 2022 7:09 pm
Post
by Bahnstormer » Fri Mar 17, 2023 3:41 pm
Hopefully fixed the intermittant problem with injector number 3 and fitted an engine cover which I found on ebay for £35 delivered
DaanBogers
Post
by DaanBogers » Sat Mar 18, 2023 9:51 am
gjseb wrote: ↑ Mon Mar 13, 2023 6:23 pm
Jep. These are from a mk7 GTD. Straight fit
