Axle Centre Plate
IainH91
Axle Centre Plate
Post by IainH91 »
Afternoon All,
Best place for axle centre plates and wobble blocks (Thinking about making this up myself, as its just a bolt and some material)?
Cheers,
Iain
Giddy
Re: Axle Centre Plate
Post by Giddy »
In general there are two types of centralising plates you may need, depending on your leaf springs. So, make sure you know which type you have before purchasing centralising plates. Few people made this mistake by purchasing the wrong ones.
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
Jayofmx
Post by Jayofmx »
IainH91
Post by IainH91 »
Giddy wrote: Fri Feb 05, 2021 4:11 pm In general there are two types of centralising plates you may need, depending on your leaf springs. So, make sure you know which type you have before purchasing centralising plates. Few people made this mistake by purchasing the wrong ones.
I remember reading this somewhere now you say it. Do you know what the differences are? I will have a look before I order.
IainH91
Post by IainH91 »
Jayofmx wrote: Fri Feb 05, 2021 9:54 pm I've a 2012, I got these.. https://www.demon-tweeks.com/eu/forge-r ... forfmaop1/
There big money for something simple.
Giddy
Post by Giddy »
Basically, you have either a bolt that goes through the leaf spring or a locating pin which is on the bottom side of the leaf spring. As a rule of thumb pre-facelift will have a bolt and Caddy 4 will have a locating pin. But the facelift could be either, so best to check.
Jayofmx
Post by Jayofmx »
IainH91 wrote: Fri Feb 05, 2021 10:27 pm There big money for something simple.
You're telling me, I paid over 100euro for them f##kin things :(
IainH91
Post by IainH91 »
A lot of kits on eBay for £35-40 delivered. Could make them myself but for ease and speed just going to buy them.
IainH91
Post by IainH91 »
Giddy wrote: Fri Feb 05, 2021 10:31 pm Basically, you have either a bolt that goes through the leaf spring or a locating pin which is on the bottom side of the leaf spring. As a rule of thumb pre-facelift will have a bolt and Caddy 4 will have a locating pin. But the facelift could be either, so best to check.
Hi Giddy,
I would assume this is the locating pin type?
Giddy
Post by Giddy »
Looks like it is. In this case you can drill an offset hole in the bottom plate and position your axle exactly where you need it to be. Pin diameter is 15mm.
Or you can get a ready made bottom plates.
IainH91
Post by IainH91 »
So basically modify the plate currently fitted? Is there a calculation on the movement i.e. move the wheel 15mm back, drill a new hole 15mm towards the back of the vehicle?
Giddy
Post by Giddy »
Yes, if you need to move the wheel 15mm, then drill a hole with a 15mm offset towards the front (doesn't really matter, coz plates are symmetrical). But you have to fit them with the offset hole facing towards the front. It will make sense as soon as you'll start doing it :)
Giddy
Post by Giddy »
That's with a 20mm offset, just to give you an idea
IainH91
Post by IainH91 »
Thank you. Towards the front of the car, trying to picture it and work it out...haha
Reason: Removed the unnecessary quote
pepi_cro
Post by pepi_cro »
So if i understand correctly if you have pin you need to drill a hole only on one plate, but it you have screw you also would need to drill hole or wide it also on third plate that goes last, the bottom one?
